Hello all, hoping for some answers, please, to an (intermittent) electrical problem I’m experiencing:
I run a small lathe-cutting outfit (for cutting records) which is based on the ground floor in a rented space in an old Edwardian building. The electrical supply to my room – or at least to the sockets - is via a modern looking consumer unit with MCBs. The MCB marked ‘Ground Floor Power’ supplies my room as well as a couple of other rooms on the Ground Floor.
My lathe setup comprises a number of interconnected audio appliances and a motor-driven lathe, but the problem component appears to be a stereo amplifier which is rated at 380 watts per channel. Basically, the problem is that when I arrive in a morning, upon switching all the appliances on (in the same pre-determined order), when I get to this amplifier, it trips the MCB. After resetting the MCB however, the amplifier is able to be switched on OK, and functions normally. This usually takes only one reset – but sometimes as many as three. I’ve fitted an RCD adaptor to the amplifier’s plug – but this does not seem to have had any effect either way.
I should mention that this problem doesn’t occur every time I switch on the equipment for the day – maybe once a week, and when all is switched on OK, I can use my equipment all day without there being any further cut-outs. All components are correctly earthed.
The problem occurs both when I’m alone in the building, and also when the other rooms on my floor are occupied and in use.
The power to my equipment is via a single wall socket which feeds a 20-long socket strip, used mainly for reasons of reducing hum.
So, where’s the problem likely to be, please? The amplifier or the consumer unit/supply: or both, or something else? I’ve asked my landlord to investigate the consumer unit/supply and resolve, but so far, no response has been forthcoming!
Thanks in advance for any advice you can give, and please let me know if you need more information. Apologies for any incorrect terminology used...
Jon
Jon
