IPAF??
Andy,I guess a shunt is climbing speak?
Please elaborate as I doubt whether you are referring to a device for measuring current!
a shunt is a rope grab
basically, short length of rope. attach one end to harness, other end to anchor. use the shunt on a short sling between harness and rope to adjust length. by tying the other end to harness, even if the shut fails, your still attached.
i trust my life with gear like this whilst climbing, so im sure it will do the job
(note, it works on single or double ropes)
SW - what does your RA think of that?
Andy,
You are almost certainly absolutely correct with it doing the job, however, being Jobe's comforter, does it meet statutory legislation for use in a work environment?
i.e. will it meet the requirements of PUWER98?
Whether self employed or not unfrotunately it still applies.
Bad I know but, tis the truth!
You must use coprrectly certified fall restraint equipment to comply with the law unfortunately!
Even if the climbing gear is stronger, which it probably is, if it is not correctly certified for use as work equipment then it is not acceptable for use.
Noz,Do you want to buy a life saving (your life saving!) device on price?
TBH I've had a look and there are so many different types it's hard to know what's needed
single point
double point
ones with a belt and side loops
and then you have the different size webbing...
what I'm after is something that passes the relevant safety standards, is going to be useful to me and that I won't need to buy something else for a "slightly" different application.
both rope & shunt comply with rope access regs (generally same equipment is used in both climbing & rope access). although this particular combination is not exactly 'certified' as a work restraint, it could be argued that if its safe enough for rope access where your suspended by it, then its safe enough to use a restraint.
---------- Post Auto-Merged at 20:24 ---------- Previous post was made at 20:22 ----------
TBH I've had a look and there are so many different types it's hard to know what's neededsingle point
double point
basically, you need back point for fall arrest. you could use this point for restraint too, but a front point give much more freedom for restraint
Andy,You are almost certainly absolutely correct with it doing the job, however, being Jobe's comforter, does it meet statutory legislation for use in a work environment?
I can see your point and you are correct, except, most specialised climbing eqiupment is far superior to the work releted equipment we use. I do know a very keen rock climber who makes up his own restraints, arrest type equipment. He did display to a H&S inspector the advantage of this on a site, the restriants we were using were approved, but lethal. The lanyard was the arrest type, a bit like a bungie coiled up, only problem was it was longer on extend than the drop we were working at, the H&S guy had to agree with the experianced rock climber, if I remember correctly he used those shunts that Andy mentioned but he also used some type of link rope between, I guess this was a type of shock absorber, but I do not know for sure, I just know that a full body harness and restriant type fall arrest lanyards were issued thereafter.
This happened over 15 years ago so my memory can not be too specific on the details, I just remember the incident and how the rock climber showed us that they were incorrect. I would assume this has all changed now.
I hired a 45 foot mobile boom 2 months ago. No card shown, no instruction on how to use it and no fall arrest system offered or advised! Reputable company too!!
