Checking a circuit diagram of a flossy, the Boys agrees.Funnily enough - That is the very question I asked my Lecturer on Monday last. And his reply was No, you just disconnect the Phase.Do you guys agree with that?
Here you are KME.I`ve never seen a "circuit diagram" for a "flossie"??????Could you post it, please boyos?
Can I ask why you need to test that far? I would test up to the switch and note on the test certificate that the florries were untested.Just a quickie, Can you do an insulation test on a fluorescent light at 250V without disconnecting it with P+N joined together. Can you do it at 500V aswell without disconnection ?
as in note "Equipment vulnerable to testing" me thinks!Can I ask why you need to test that far? I would test up to the switch and note on the test certificate that the florries were untested.I am assuming this is a periodic.....
Here you go ?:| ; \I`ve never seen a "circuit diagram" for a "flossie"??????Could you post it, please boyos?
