- Oct 30, 2022
- 47
- 22
You should be getting a good 30-60% charge some days I would say even with our dodgy weather this month on a typical 10-13 kwh battery and that many panels in the UK.
Did they fit optimisers on the solar panels ?
What size growatt battery ?
That inverter only has two string inputs, and you have three orientations so the panels are not on perfect orientation will be holding back the ones that are at a good orientation at varying times of the day.
Your array may not be reaching the startup voltage of the inverter because of shading, causing the 0 input.
Can you click the tiny I icon in the app and post the daily breakdown which shows charge and load in the house.
If they have monoriting, ask them how much its making per day and ask them if they think its similar to other houses they have done.
