gary Wright
Hi all
You helped me a few weeks back when i had a problem with my wall mounted television where the plug stuck out too far and got in the way of the wall mount. I installed a single switched, fused spur and it worked perfectly!
I now have a similar problem but this time i want to put a wall mounted television with a sound bar below it but again the two square pin plugs will stick out too far and stop the tv being hooked onto the wall plate.
The solution, as before would be to take out the square pin double socket and replace it with a double switched, fused spur with a bottom outlet.
Do these double spurs exist - I have searched the net but cant find any? I want the tv and sound bar as close to the wall as possible so I don't want to use mounting plate extenders!
Any manufacturers or websites would be very much appreciated if not any other solutions / quick fixes would be great.
Thanks in advance
POWER TO THE PEOPLE
Regards
Gary
Thanks in advance
POWER TO THE PEOPLE
Regards
Gary
