I am a DIYer and started the process of fitting a spur from a socket (and from the ring) in a house. A few days ago I converted an old immersion switch into a plug socket. It was linked to the boiler and I had to isolate the boiler after there was continuity with the N/L.
Back to the spur. Using a voltage and continuity tester (this: https://www.test-meter.co.uk/voltage-testers/handyman-tek900-voltage-and-continuity-tester/ ) I turned off all the MCBs and RCBs plus the main switch in the Consumer Unit. I did the isolation tests at the CU. All showed there was isolation.
I opened up and checked a plug socket using the volt and cont tester. When I tested the ground with the line/neutral the tester showed 400V and beeped. I also checked the shower on/off switch which was the same - 400V. This problem was not seen at the boiler socket spur.
When the CU is turned on and not isolated, the socket and switch which read 400V when isolated is normal at 230V.
Any ideas what issue this could be?
Many thanks.
Many thanks.
