isolator location
haddow
May 9, 2011
7
Hi will the DNO fit isolator in the external large white plastic meter box? Asking cos if this is not possible and the tails come straight through the wall into back of CU where can you put isolator?
thanks
If it's a new supply or supply relocation then they will fit an isolator as that will be the end of their responsibility,,, if it's existing then you might be able to get them to fit one (at cost) or just get them out to isolate the supply while you do the job and re connect afterwards!
A lot of guys don't like the idea of an extra link in the chain that could fail
