JTI sparks
- Apr 16, 2012
- 15
- 0
Hi. I'm a newly qualified spark and my grandfather has asked to install lighting and power in the shed.. The DB is miles away and old school with fuses rather than our beloved mcb's and the likes.. So instead of tearing through the house to put in an armoured cable and a small 4way DB in the shed I was wondering if it's acceptable to spur off the ring main with an IP rated (socket or other) and run a sy multi-flex steel wire braid cable to the shed (5 meters away) which I will bury.. And connect this to a double socket in the shed.. Is this acceptable..?
