polarity
- Joined
- Jul 10, 2009
- Messages
- 62
- Reaction score
- 0
Hi All
Another kitchen question...
Installing a wall mounted extractor hood as pic , no units to side or above.
ideally would like to cut into the wall and run its' (pre-attached, flex) cable directly down to below the work surface and right into the next cabinet to a patress socket box - ie as if it was an integrated appliance.
A glass panel will then be mounted as a "splash back" for the hob area and will cover the cable run.
There is no safe zone between extractor and hob created by doing this as there is no visible box. I could put one inside the chimney or under the worktop but it still would not be visible!
Having said that there will be a glass splashback covering the cable - that can not be drilled through (and if you tried the wire would instantly become visible behind the pile of broken glass!)
Does the wall mounted appliance creat its own safe zone?
Is there an issue with using the existing flex to run behind the glass or would I have to join to or replace with T+E.
Can I use the socket or must I use a fused DP switch.
Thanks !
(Yes this will be inspected by LABC)
Thanks !
