Hello,
I'm looking for some help on changing a light in a kitchen. I don't have much electrical experience but have the basics to change simple sockets / switches etc.
This kitchen light wiring (2 switches at either end of the kitchen) isn't something I recognise and hoped someone here could explain in more detail:
From the ceiling I have 3 sets of wires, one of which has an Earth wire the other 2 do not appear to...?
All 3 of the live wires from the ceiling are run into a connector which appears to do nothing.
The remaining 3 Neutral Black wires are run as follows:
The black wire from the set with the earth wire is run into the "L" section of the fitting which has the Live load wire to the light
The other 2 black wires both run into the "N" section of the fitting which also has the Neutral Load wire to the light
The "LOOP" section of the fitting has 3 holders and nothing currently connected
The current fitting is a basic light bulb and wire job, however I want to change this to a chrome 4-spot unit but the wiring doesn't appear to match up!
On the new unit all I have is 4 double connectors: N, Earth, Live all of which match the unit wiring and one double connector which is unmarked.
I would really appreciated some help with this one!
Many thanks
Chris
Many thanks
Chris
