Kitchen renovation.
Badfish
Aug 16, 2010
212
I have just started work on a kitchen renovation so i so i have taken some pics.
All i have done so far is take down the ceiling and start to take out the old sockets. as you can see i have found some interesting DIY electrical work.
Nice nest, bet you got a surprise when you pulled that section of plasterboard down?
Was a bit cautious when I first saw the nest but it was quite obvious that it was dormant.zee can't see any brickwork I think that you maybe looking at the wall where the tiles have been taken off. Will be more photos soon.
Ah thats not me in the ducting bend it's the guy from the wholesalers.mind you, wouldn't want a load of bees down the back of that.
I look forward for the "During" and "after" pics of this mate - Thanks. :)
Hi Badfish
May I ask You , if you do not mind mate, how much did you quote for this job(ruffly) and consisting in what from you.
Cheers
Koko
Looks great mate - thanks for the updated pics.
May I just point out two observations and they are in no way, any criticism.
1. In pic 8 I see your T&E running under, instead of through the noggin. (not 50mm from the bottom of the joist, but running very close to the bottom of it).
2. In pic 16 from the end of the three clipped T&Es to ceiling joist, it looks tight.
Like I sid, Fantastic work, and thank you for the pics.
Anyone else want to post pics of their work?
:x
Looks great mate - thanks for the updated pics.May I just point out two observations and they are in no way, any criticism.
:x
Check out my new method of connecting SWA to a JB. You like ???
http://i1201.photobucket.com/albums/bb346/m4ttyd/IMG_1548.jpg
It was fed in 2.5mm T&E from a 32A CPD to this JB then SWA fed upstairs into Loft for upstairs sockets. Same style of joint in loft with JB feeding sockets. The flex goes down to a 4 gang trailing lead for use outdoors. (most prob for lawn mower)
Started second fix yesterday.here are some more pics. Will finish off on Monday as floor tiler was in today.
Yes the wall are pink, not my choice.
