kitcken socket
rugbymacc
Nov 27, 2008
322
feeding their tumble dryer !!!
<a href="http://s215.photobucket.com/albums/cc287/rugbymacc/?action=view&current=Image020.jpg" target="_blank"><img src="http://i215.photobucket.com/albums/cc287/rugbymacc/Image020.jpg" border="0" alt="Photobucket"></a>
<a href="http://s215.photobucket.com/albums/cc287/rugbymacc/?action=view&current=IMG_0737.jpg" target="_blank"><img src="http://i215.photobucket.com/albums/cc287/rugbymacc/IMG_0737.jpg" border="0" alt="Photobucket"></a>
Was it the socket or the plug at fault?
You never can tell sometimes, although often the fuseholder in the molded plug is a common cause of this problem, with age.
The Godfather
Was it the socket or the plug at fault?You never can tell sometimes, although often the fuseholder in the molded plug is a common cause of this problem, with age.
The Godfather
it mostly happens with a moulded plug, so i would guess the plug is at fault most of the time. one problem being though, since its moulded, it cant be visually inspected for loose connections, unlike a normal plug which can be checked after something like this
Yep, had a few of these in my time, some you couldn't even sperate!
headbang
