Rob_the_rich
Sock Muncher
- Mar 2, 2010
- 1,343
- 27
did you need the stabilisers because you were chopping out the bricks on rhs which were holding up the steel which the ladder was leaning on?
I assume the truck driver used his/her truck to do this? That just sounds poor, how is a bit of cement on the bottom going to help? There is no bearing for the steel at the top, should have had a padstone surely.the truck driver removed the bricks. and twisted the entire column. then the brickies fixed the problem by putting some cement around the bottom where it had moved...
few weeks after the shutter / column was repair it was hit again
