I do not agree at all. Fitting an earth clamp to a lead pipe is not 'working on' or 'altering' the pipework. You would never ever ever get prosecuted for doing so. I have seen hundreds of BS 951 clamps on leadpipes and have never seen nor heard of one that has crushed, disformed or corroded the pipe. I have also neither seen nor heard of a BS951 clamp that has 'worked loose' as it has bit into the pipe (yet another old wives tale). This includes cutting open many removed lead pipes to check.legally cheggers if you point out to the customer that their installation does not meet the current regs and in your opinion it is unsafe then you are covered.remember, its not against the law not to have bonding, its a deviation from the current regs.
but NOT illegal in a building that was wired to a different version of the regs, ie, 13th or 14th.
you DO NOT have to make the customer do something they do not want, you only have to leave the install in as was or less dangerous condition, you do NOT have to make it any safer.
IMHO if you bond to lead pipe you are either
A- breaking the law by modifying a lead plumbing installation
B- breaking the law by not using a clamp designed for lead piping (Im assuming you are not a qualified pipe jointer certified to work on lead)
there is a limitations box on your cert, also there is a box for observations, and if you really wanted to you can issue a failure to comply cert, get the customer to sign, you both get a copy then its up to them to rectify the fault, you have your signed copy to wave in court.
as I said, these are only my opinions based on past experiences, others may have done it differently, but Im not a plumber.
The NICEIC's view on this matter is to try and fit the clamp on the nut of the stopcock. I commented that where this was not possible i had fitted the clamp on a sweated joint ( these are a raised lump which have double thickness lead due to the join). There reply was ok. However you can get different views depending on who's answering the helpline that day.
I also remember a few years ago surveys being carried out to test the lead in water, and there was nothing much higher than a no-lead installation.
