jcstockdale
- Jun 9, 2017
- 4
- 0
Hi All,
I'm completely new to oil boilers and plumbing in general having only just bought my first house. We ran out of oil recently and when the new delivery came, there was air in the supply line. I tried bleeding it but nothing seemed to come out. So, perhaps foolishly, I started dismantling connections leading back to the tank. The oil was eventually flowing but I can't reassemble the whole line without getting a small leak at the shutoff.
The image top left shows most of the assembly. Top right shows the flared copper pipe that connects up at the right of this. Bottom left shows the end of the flexible fuel line. Bottom centre and right show each end of the shutoff valve.
What I'm wondering is whether these are all metal to metal joints or should there be some additional rubber seals or PTFE tape or anything like that. I've a feeling that the problem is with the flared copper pipe (if that's what it is). I thought that the flare nut should be pushing this up against the rubbery looking bit inside the shutoff valve but now I'm not so sure. Is there something missing here? I've cleaned up all the metal parts so there's no paste or tape there. Do I need to reapply any kind of sealant? If so, where? Or maybe parts need adding/replacing. Please help!
Thanks,
James.
Thanks,
James.
