- Nov 5, 2011
- 26
- 1
Hi all. I have a cold plunge barrel with an 1W LED bulb in. Water is cold c. 3-5 degrees. Light used to come on instantly but now takes a minute or so then flashes a bit then comes on eventually after about 2 mins. Do you think the delay is the bulb or driver warming up or is it just a sign the bulb needs replacing (big job as need to drain barrel)? It is not old maybe 6 months (but 6 months in cold water). Pic of bulb attached if relevant. Thanks a lot for any views
