Hahaha that's pretty true One teacher = one lampThings are tight at college they can only afford one lamp.
We're not allowed in the booths yet I think they wanna make sure that we have a bit more of an idea of what we're doing before they let us loose in there.When I did my apprenticeship, we did our work on a wall, not on a floor. And the lamp holder was on the ceiling on the roof of the "booth" so a bit more realistic to real life.the main thing is to make sure you understand what you are doing, rather than just copy parrot fashion.
Thank you!Looks great.Someone has stolen your pliers and small terminal screwdriver (you don't get more realistic to life than that )
TUT TUT FredLooks neat, you could do with a sparky to fit a bulb though :coat
That'll be to save on the fees :^O same way they've reused the boxes, used to love how much I had to pay at college to have the tutor tell us to use and reuse and then reuse again to save money, should have seen the state of the earth clamps they used to give us to practise bonding pipes with, it was impossible to get them tight the condition they were in.only criticism I'd have is the T&E doubled under one clip between switches.
I'm at Bracknell doing C&G 2365 Level 2.Looks good, only criticism I'd have is the T&E doubled under one clip between switches.What college are you at?
I have a question here.Looks good, only criticism I'd have is the T&E doubled under one clip between switches.What college are you at?
I would second that but at least the clip pins areLooks good, only criticism I'd have is the T&E doubled under one clip between switches.What college are you at?
