I have a double switch which I would like to use to control two lights. There are two cables coming in to the switch area from two existing lights. I have a feed from the consumer unit to go to the switch but am unsure how to correctly wire it. I enclose a diagram which hopefully will be of some use. At present there is a link between the two 'one' terminals (common).
Brian
Brian
