- Feb 10, 2009
- 342
- 17
I've been looking at a domestic lighting circuit today. Singles within steel conduit.
With line and CPC connected in connector strip at CU, I measured R1 + R2 at a switch. At live side of switch got reading of about 0.7 ohms. At dead side of switch got around 140 ohms!? So I tried various things to locate problem but without success. However I did notice that when I close a switch in adjacent room then at the original switch at the dead side I then get a reading off the scale as expected!?
R2 at all points in the circuit is acceptable. Took R1 + R2 readings at all points - roughly half where under 1 ohm and the other half around about that 140 ohm figure again.
Has anyone experienced anything like this before? and is this the result of the switches some how having been connected in series? headbang
