Chris_81
- Oct 28, 2008
- 108
- 0
I was talking to someone today thats just had their wiring tested so they can rent out the house. The bloke that did it condemned the lighting circuits as they had no cpc and only advised that the two old wylex rewirable c/us needed changing (covered by a 100ma rcd before the boards).
I can understand where he was coming from as a lot of the lights and switches were metal and definitely not class 2. No other faults on the lighting circuits. However he said that changing the fittings to all plastic or class 1 wouldn't surfice and that both light circuits needed rewiring before he could sign it off.
I was under the impression if the fittings were changed you could just note it down as having no cpc on the form, but he was adiment that it would be illegal to do that as all circuits had to have a cpc where it was being used or not.
Is he correct or just trying to get more work?
