Lighting issues in a bungalow
Theorysparky
Domestic Electrician
Feb 18, 2008
4,232
Testing a bungalow prior to a fuseboard upgrade
there are two fuses for the lights,,,,,,partially marked up
after finding loads of issues i discover they are interconnected,,,,,,i try to find the connection
decided after a while that best option would be to put the whole lot into one mcb,,,5 wires
now would you guys connect them altogether (in an appropriated box) in the loft and feed one cable to the cu or try to fight with them so they are visible
i have recommended the lighting is partially rewired which may be done at a later date,,when funds are available
back there on tomorrow to the house of horrors
Is that two fuses protecting the lighting circuits?
Or rather as it will not be?
2 fuses protecting the one lighting cct at the moment
want to put them on one...
2 fuses protecting the one lighting cct at the momentwant to put them on one...
I'm confused.
Are you saying both "circuits" are joined together?
If so is this L and N, or just a borrowed neutral issue?
If L on the two "circuits" is joined, then I'll bet this is a more recent addition or alteration gone wrong, rather than them being like that originally. I would want to spend at least some time trying to find the fault and understand how it's wired.
Why not connect one leg into DB put the other leg in blocks then see if lights come on through out the dwelling then check if there is a feed in the leg in the blocks if so trace it back and disconnect.
They have wired it like a ring main.
I have a good idea where it is,,,,,,
it does not look to be an addition......
the trouble is the old girl hasnt got the funds for me to investigate fully so my idea was a quick fix
i will be asked back as her daughter is frightened about electrics,,,,,,,got to finish testing tomorrow and go from there
other issue 100 mile round trip !!!!!! so cant keep going down there
Could you just not split it up by taking a new feed about half way round JB it there so it properly split. On bungalows thats what I do if there is only one circuit especially with elderly people you won't be popular leaving them in darkness if trip trips.
that what i would like to do,,,,,,
i will try and take a photo of the jb thats already there .....then you will understand why i want to rewire it !!!!
its a right dogs dinner....
Spam?
EDIT
This post now looks silly, now that the offending post it referred to has gone.
Perhaps this post should also be deleted.
