Oops :Blushing Slight dyslexia coming on!Damien. its very common practice to do it.Take a look in Appendix 15 at the back of Bs 7671
Dont look in bs6761 though !
In appendix 15 (of BS 7671 ) it shows examples of various socket spurs from socket circuits but no examples of lighting spurs from socket circuits.Damien. its very common practice to do it.Take a look in Appendix 15 at the back of Bs 7671
So can i connect my 9.5kw shower to it then ; \ ; \A fused spur can feed any load you want so long (as stated above) as protection is correct.
Of course you can. It obviously won't work as the fuse will blow but the cable will be adequately protected, assuming you use 2.5mm2 or above.So can i connect my 9.5kw shower to it then ; \ ; \
