samporter75
I just swapped over a light switch and now my lights are permanently on… I was assuming it was a loose wire but I can’t see one.. anything else to check?
So there are 4 witches that control the same light… 1 of them is working and switching the light off and on, but the other 3 aren’t doing anything…. Added pictures if it helps…
Do any of the lights in the adjacent rooms not appear to be working correctly ?
Could it be that the switch the com on is somehow now faulty or would that just not happen?
Which one? The one on the left or the right?That’s an intermediate switch
And what’s the impact of that?Which one? The one on the left or the right?
That was the issue…. I had the L1’s and 2’s mixed up on the first intermediate I did…If all that you’ve Done, the cables can’t be in the same places in the new switch
no, you just got it wrong, which is easy to do.Could it be that the switch the com on is somehow now faulty or would that just not happen?
