already ignoring his non-sense.Will you two play nicely, please???(not you, Lurchie - for once
KME
KME
Oh shut up!!!!!!Depending of course on length of cable.
As per post #6, on page 1All I can say is...Flex!!!
got to be in a plug top!!!!
even if you need 1.5mm sound upto 16A!!!!!!!
(pg 296BRB)
I'd probably say you'd get a 2.5 into a decent plugtop. 4mm I wouldn;t even bother trying, 16A plug and then short 16A socket to BS1363 adapter made with 1.5 flex.If the length is going to be excessive, 2.5 flex will go into a plug. I "think" 4mm might; at a squeeze (and it flippin would be!)
That badger set is 550m away..............I'd probably say you'd get a 2.5 into a decent plugtop. 4mm I wouldn;t even bother trying, 16A plug and then short 16A socket to BS1363 adapter made with 1.5 flex.Would have to be a bloody long way to start needing 2.5mm, or even 4mm at 13A max.
