avinalarf
- Jun 2, 2008
- 415
- 0
Sorted out a faulty light at a rented property over the weekend. Owner has asked me to let her know if anything else needs doing...
Just as a taster - there were 2 metal light fittings in a room, neither of which had earth connections . One of them had a hand-written note on it stating "do not touch as you will receive a shock - isolate first"
The CU was in the shower room at ceiling height (not on the ceiling). I checked the BRB with regards to this, but couldn't find anything specific apart from reference to condensation, which obviously applies in this case.
Anyway, I'm assuming a PIR is required in order to answer the owner's question??? Someone please correct me if this is not the case. Referring to a different post - I don't feel 100% confident enough to do these yet, so will ask someone else if one is required.
Cheers
Cheers
