septiclecky
Distinguished Member
Only the person that opens it :slapdo you need a tool to open a cupboard door?
Its classed as a different room,do you need a tool to open a cupboard door?
this is the silliness of the regs. You are correct, the FCU should not go under the bath, but then how often is it likley to be switched off? Yet we can walk about the house soaking wet through and access lots of electrical items. Just trying to think if you put the pump on a plug and fitted socket under bath whether or not that contravenes regs or not as it would not be classed as a fixed electrical item, ergo no immediate need to have an accessible switch 'for emergencies' ?Its classed as a different room,
You know,? Like the wall with the door that you have to open to enter the bathroom, or bedroom, or kitchen,
I don't see an issue with a screwdriver being needed to access a bath panel. What's the big deal?
Concealing a FCU, behind a fixed bath panel is plain daft.................................
