- Joined
- Oct 22, 2010
- Messages
- 14,510
- Reaction score
- 1,080
Yep. And the stub sleeping ! The PROPER stuff withnthe little raised bit on the end!Did you do the thing with keeping a stick of compound in the trouser pocket when it was freezing cold onsite. ?
Ah yes that was it , not Fire Alarms , explosive areas . There was the extra long gland thread about 35mm long to fit into the thick cast boxes , or you could use the standard gland as long as it had the EX rating marked . I think that was right .The one I'm thinking about was ok for Fire Alarms but not suitable for petrol pumps or and explosive atmosphere
No never heard of those . Was that during the Great Copper Shortage when they were pushing twin /earth in aluminium . ?Remember AlCu MICC. Use the wrong pots and it dissolved the sheath in damp atmospheres. All fittings had to be sort of galvanised/sheradised/tinned
Near enoughAh yes that was it , not Fire Alarms , explosive areas . There was the extra long gland thread about 35mm long to fit into the thick cast boxes , or you could use the standard gland as long as it had the EX rating marked . I think that was right .
For 2.5 copper you had to use 4mm Alm. And use Densal paste on on the al. to Cu. terminals . ?
I worked on the site in St Helens where the shrink on pots were first used before they were released for sale, remember we had loads of teething troubles with the supplied blowtorches fitted with a shroud to shrink the sealUse to do a lot of Pyro work in the 80’s I vaguely remember for a brief period in that time we were issued with heat shrink type pots to put on the ends instead of the usual self tapping type. None of us liked them, didn’t save much time and they looked terrible, to me one of the plus points about Pyro is that you could make a right tidy job with it.
Very niceI don't tend to clear things out of my garage, rather just move them around and add things. My latest addition to keep me quiet...
Sounds like a “proper” garage to me.I have loads of space in my garage, an unbelievable amount. However it is occupied by
thicknesseser planer
band saw
radial,arm pillar drill
2 lathes
linisher
grinder
polisher
2 table saws
2 chop saws
chop saw stand
4 work benches
ladders
mig welder
steps
10m Zip,Up,tower scaffold
stick,welder
ingersoll,rand compressor
2 roller cabs
stock
infinite amount of tools
all wife's riding gear
workmates
stands
portable benches, etc
....and then there is all the power tools
and all the other stuff
just tidying
