Check out this thread...What type of lockoff devices do you use. As there a so many makes of MCBA RCD I did a search to find a one fits all unit and came up with this has anyone got one and if so does it work.
Those are the good points for that type of lock.. :xApplaud SmileyWhats good about the Kewlock is that it is a one piece device. No extra bits like an allen key to do it up (That ***10), no locks or keys. And you won't forget the combo because you'll use your PIN or the last 4 digits of your phone number.Me thinks I'll be getting one.
Those are the good points for that type of lock.. :xApplaud SmileyHowever..
the down side I can see is I have on occassions wanted to lock off more than one circuit!
working on an extension...
shifting some cables so wall can be removed...
Sockets + Lights + Cooker passing through..
3 locks at
Not if you don't want to take the lid off the CU!!!!you lot must have more money than sense, cheaper alternative is just remove the live cable from the mcb and job is as they say a goodun Applaud SmileyApplaud SmileyApplaud Smileycoffee
Which if you're going by the book (assumed you are if you are using proper lock off devices) you shouldn;t really remove the cover to live devices anyway until they are isolated.Not if you don't want to take the lid off the CU!!!!
Unless its a modern CU with integral secondary barriers over the live parts!Which if you're going by the book (assumed you are if you are using proper lock off devices) you shouldn;t really remove the cover to live devices anyway until they are isolated.
You always have to go one better!Unless its a modern CU with integral secondary barriers over the live parts!
