Emwol2
Hi I have a Chrysler voyager (03) and the main beam headlamp on the left won't work. If u disconnect the fcm unit and put a connection from the connection wire to the battery no lights work - but if u connect direct from battery to the bulbs then they work. Do u think I need to to replace the fcm unit or the wiring? Can't see any loose connections or signs of corrosion but have spent a fortune so far trying to get this car through mot and this is the last bit to be done so want to avoid spending out too much by guessing!
