What do you mean when you say ISO?You can have a RCD as a main switch instead of an isolator, but if you get an earth fault on any circuit they will all go off. Best is a ISO CU and RCBOs, but we often fit dual RCD boards to keep costs down.
Doesnt that rather depend on other factors. Like 3 circuits, Lights, sockets and cooker so what would be the benefit of splitting those over 2 or more rcd's?You CANNOT have an RCD as a main switch or isolator in a domestic installation.
Really, so a 100mA Time Delayed RCD as a main switch would be wrong. Erm no.You CANNOT have an RCD as a main switch or isolator in a domestic installation.
Yes you can.You CANNOT have an RCD as a main switch or isolator in a domestic installation.
Erm yes it would as all circuits must be protected by a 30mA.Really, so a 100mA Time Delayed RCD as a main switch would be wrong. Erm no.
Yes you can. Where does it say you can;t?Indeed, but you still cannot have an RCD as main switch.
No you wouldn't.You would therefore need to install a standard 4 or 6 way cu with RCBO's.
That has nothing to do with it. And all circuits don;t have to be protected by a 30mA RCD anyway.Erm yes it would as all circuits must be protected by a 30mA.
Wrong yet again. Depends on how the circuit is installed and what its for.Erm yes it would as all circuits must be protected by a 30mA.
I'd also take a quick look yourself.I really cant believe some of the replies i am reading here.Maybe a read of the regs will help you?????
Its there for a reason.
Yes you can.You cannot have an RCD as a main switch due to nuisance tripping IN A DOMESTIC INSTALLATION.
It isn't. If the system is designed properly the RCD as a main switch will not be an issue.The OP asked if you could have an RCD as a main switch, to which the answer is no, due to the above.
Try including reg numbers when claiming regs support your side please.I really cant believe some of the replies i am reading here.Maybe a read of the regs will help you?????
90% of the guys posts ignore everything anyone else says.As I've said before, I'm all for a good discussion\argument but you're just arguing for the sake of it.
Yes, it's a common scenario. However, that exact setup wouldn't pass an inspection assuming the RCD is 30mA and you live in a 2 storey semi. Usually it's done for cheapness, not the best way TBH.My CU (consumer unit before we go down that road) only has one RCD and it is the isolator as well. I believe it was fitted in 1988. I have had no nuisance trips and it is tested regulary.
Isnt that something along the lines of what i was TRYING to get across?that exact setup wouldn't pass an inspection assuming the RCD is 30mA
