What's the difference between time delayed and not time delayed?If it was not a time delayed one then most likely yes.
Am I right in saying though that 30mA RCDs protecting circuits won't be time delayed?It will wait a specified time before tripping to see if the fault clears (or is cleared by another protective device)
Generally no, 30mA RCD's are not time delayed as they are usually there to protect the final circuit. It is the upstream RCD's that will be time delayed as they are there for general overall protection so are effectively a last resort.Am I right in saying though that 30mA RCDs won't be time delayed?
So there are 30mA time delay RCD's available ?Generally no, 30mA RCD's are not time delayed as they are usually there to protect the final circuit. It is the upstream RCD's that will be time delayed as they are there for general overall protection so are effectively a last resort.
Good question, never looked TBH. Task for later.So there are 30mA time delay RCD's available ?
It would depend, there is no reason why you couldn;t use 30mA time delayed RCD's as long as all the measures for protection are met. It could be that the final circuit has to have a 10mA RCD for protection for whatever reason but the 30mA is used fro the wiring due to being <50mm, or something. Dunno, could be used though.I wouldn't have thought that Time Delay was available on 30mA RCD s. Due to them deing used for Electric Shock Prevention? :|
Mine is the same from about the same era too, Hagar (YUCK!) but no problems to date.My CU (consumer unit before we go down that road) only has one RCD and it is the isolator as well. I believe it was fitted in 1988. I have had no nuisance trips and it is tested regulary.Cheers Steve
Remember that you must allow for cumulative earth fault leakage.Am I right in saying it's possible (although not probable) to use a 30mA RCD to protect the circuits and a time delayed 30mA RCD as the main switch?
One final question - With regards time delayed main switch RCDs, if a 30mA RCD protecting circuits trips, as the RCD would then be in the OFF position, am I right in saying that this fault current then WOULDN'T feed through to the main switch RCD?Remember that you must allow for cumulative earth fault leakage.Computers are known to have earth fault leakage, as are cookers, fridges and freezers.
Yes.One final question - With regards time delayed main switch RCDs, if a 30mA RCD protecting circuits trips, as the RCD would then be in the OFF position, am I right in saying that this fault current then WOULDN'T feed through to the main switch RCD?
No, 2 posts to answer it, 3.5 pages to argue the point for no apparent reason.Wow four pages to answer a simple question.
Oh dear! :_|You CANNOT have an RCD as a main switch or isolator in a domestic installation.
That's not what you said though. And it wasn;t a matter of proof reading anything, it was a matter of your blanklet statement which was incorrect. You can say whatever you want, but you cannot say that what you said was correct, which you clearly have an issue with.Even in a TT system, you no longer need to have a 100mA s type RCD as a main switch.And yes, it did take many pages to get a point across.
It just seemed that i didnt put my posts past "those that matter" to proof read.
