Hi All,
I would like to get some advice on this attached plan.
For reference the 3 phase is for wood working machines will be using 3hp or lower hp wood working machines at 15amp.
I have used a 32amp MCB between the isolator and busbar. Because the here the domestic 3 phase is provided at 30amps and the main wires are rated at 36amps(6mm) for 3 phase. Also the busbar splits into 3 circuits (2) Single phase (1) 3 Phase. Any advice on this?
Thank you.
Thank you.
