brummydave
Evening!
This query relates to a flat above a shop. In the shop are the DNO supply fuses, meters and more.
Does every part of an installation after the meters actually belong to the customer?
If so, how does a supplier fit/ bill for a separate meter in a flat?
If not, how does ownership differ in this mixed commercial / domestic setting?
The flat is empty as previous tenants were evicted after growing things they shouldn't so i'm planning a rewire.
Hope the pictures illustrate the situation, but here's a summary:
The shop has one supply cable with two 100A fuse carriers (no record of what's inside). One fuse supplies the shop smartmeter (changed 2018), supplier is Scottish Power. The other fuse supplies an old 40A analog meter that then feeds a 60A fused switch. Tails from that go up into the flat above the shop. The Neutral goes directly into the flat consumer unit main switch and then a second cable goes from there to the pre-payment meter in the flat. The Line goes into a henley block below the CU, then to the pre-payment meter and on to the CU. The meter has lots of debt on it, so is not passing power through, has no cover for the terminals, and belongs to E-On (according to Western Power's search facility).
I left the flat fully isolated by turning the switchfuse off in the shop.
For the rewire i'd like to install new tails from the switchfuse in the shop to relocate the consumer unit to a more convenient spot. Can i move / remove the pre-payment meter as well do you think?
I've got more questions but will post separately as they're not to do with metering!
Thanks.
Thanks.
