To fill the gaps left in the conversation here
Here and there, especially from manufacturers I read that DC Coupled system with batteries can only be done:
1) with hybrid inverters
2) The hybrid inverters must be compatible (kind of only works with the same brand). I don't believe this.
I see from Victron ESS training this diagram
Apart from the PV inverter on the right (with the critical loads) the rest is exactly what I want to do. I have a grid tied inverter since 2016 and I want to add more panels (3 times the current kWp I have 4kWp and will add 12kWp), so I think DC coupled will be better (originally I thought that I will have to have ac coupled (I was told so last year by some installers and I stuck with it) but now I realize I will lose a fair bit. DC->AC->DC->AC means between 10 to 15% loss from what I read in several places. Due to the fact my new panels are expected to generate at least twice as much energy as my existing panels (the orientation won t be as good as my existing panels but there will have higher efficiency and Wp). I think it is better to connect the battery as per the Victron's diagram.
The guy from Victron from the video below. clearly explains that the MultiPlus will always manage the "PV on DC", the "PV on AC Input" and the battery to ensure the import from the grid is 0 as much as possible.
Therefore, I don't understand why they talk about hybrid inverters. In the Victron scenario, there is a MPPT charge controller and an inverter. That is.
Furthermore, can batteries such as the fogstar rack 48V be used in a DC coupled system?
Victron video (first 6 minutes are the most interesting)
Thank you
Thank you
