More Sbs Rcbo's In Use
M107
Billy-the-Kid
Feb 18, 2008
5,561
28
Berkshire
Just a few more pictures.
Upgrade of old switch gear
http://i83.photobucket.com/albums/j293/gazjothomas/20131108_084939_zps7304371c.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20131108_113010_zpsd2121676.jpg
Yesterdays cu upgrade
The old
http://i83.photobucket.com/albums/j293/gazjothomas/20140111_095745_zps0f2f3dcd.jpg
The new going in
http://i83.photobucket.com/albums/j293/gazjothomas/20140111_104803_zps400d000e.jpg
Extended circuits to new board location so pensioner can reach with out having to use steps.
http://i83.photobucket.com/albums/j293/gazjothomas/20140111_104809_zps4de48dfc.jpg
Done
http://i83.photobucket.com/albums/j293/gazjothomas/20140111_123302_zps6321b229.jpg
Last weeks install of an inverter system on a communications support vehicle.
SBS Daves compact rcbo's have been used.
12v - 230v inverter / charger / change over switch & a split charge switch.
http://i83.photobucket.com/albums/j293/gazjothomas/20140110_145602_zps2625cdd8.jpg
Auxiliary batteries supplying 12v to the inverter & fuse
http://i83.photobucket.com/albums/j293/gazjothomas/20140110_145615_zps41456b3c.jpg
New sockets installed to power laptops / one blade server / UHF radio / Tetra radio / Mobile Data Terminal / radio battery chargers
http://i83.photobucket.com/albums/j293/gazjothomas/20140110_145658_zps45ece07b.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20140110_145714_zpsb1e994be.jpg
More sockets & Aerohive Wlan AP
http://i83.photobucket.com/albums/j293/gazjothomas/20140110_145726_zps2e7471a9.jpg
Yes mate it is pure sine wave but is 2kW continuous on one supply, but it will sync batts/gen or mains to give  4kW peak for 3-4 mins. We went for this unit as it is everything in one box; inverter / charger /ups mode switch over/auto change over switching.
This might be what you want
http://www.antares.co.uk/pure-sine-wave-inverter.html
What ever you go for don't scrimp on the batteries, get some decent Cyclic Gel Batteries it will save money in the long run.
We have tried a few inverters from varying companies, but the ones supplied by Antares are spot on & their customer service & Tecc'y dept's are on the ball.
Yes we have a Victron system on our 15 ton Merc Atego control unit. works well & does what is needed.
Again it is supplied via a battery bank / mains or a Fischer panda on-board genset.
