Switch Snow
Hi to all those willing to comment and advise. (Said with caution)
Though I'm gradually gaining experience having completed a number of installations, I've often found info on this forum useful but until now haven't needed to ask for specific advice.
Along with a full re-wire, a customer wants their C.U. moving to a point under the hall stairs ( approx 10 meters from meter)
I appreciate that the first thing required will be a fused switch close to the meter. (Though I can only find these rated to 80a, wouldn’t this make the 100amp switch in the C.U. irrelevant? can you get a 100amp fused main switch?)
My main question though is, is there a preferred option for running from the fused switch to the C.U.?
(Bulk of the run will be visible in the cellar with approx 1.5 meters needing to hide / be buried as it comes up the hallway wall to the C.U.
Would you advise 25mm SWA ? or 25mm tails (16mm earth) with some steel plate (earthed) protection as they become concealed? or any other options??
The house is a fair size ( 4 Bed ) with TN-S earthing.The current installation already has a similar set-up with an old fused switch next to Meter & 16mm tails run approx 15 meters to the old fuse board in the kitchen. However this was possibly done by the old fella that used to live there, and anyway the regs have moved on since this was installed.
I appreciate all advice and comments.
Thanks Switch Snow
Thanks Switch Snow
