Before the heater was installed, when I got up at 4am the smart meter read 5p usage, since it was installed it's reading 28p usage ??? Both switches are off???Are you 100% sure its the storage heater? Is it getting warm/hot?
How many units are being recorded nightly?
Economy 7 overnight records all electricity used in your property, so it could be all the other appliances you have plugged in
The heater isn't warming up either?Jarbo said:Before the heater was installed, when I got up at 4am the smart meter read 5p usage, since it was installed it's reading 28p usage ??? Both switches are off???
Modern storage heaters are forced by EU law (LOT20) to have clever energy saving controls. So there will be a circuit board and probably a display panel on the heater that is now running 24/7 and consuming some power. In this case it looks to be using about 23p worth overnight, which does sound quite a lot.
