Hi I am not a sparkly thinking of buying a multimeter I don’t want to spend a lot so what would you guys recommend or even buy a second hand one I have a new fluke continuity tester. Do you guys have anything suitable for me I just want your opinion cheers folks
As with many things, what is good for one persons application may be overkill or substandard for another persons application..
{bit like asking what is a good car to buy?
A family of 5 wanting to tow a caravan and tour Europe is a big difference to a 60year old widow needing transport to go the the shops and occasionally visit family 7 miles away!}
So you need to consider what it is you want to do with it? What are you expecting to be able to test.. to what level or accuracy?
If you just want something for testing if a fuse has blown, or if some batteries are discharged or for a bit of hobby electronics, or a bit of auto-electrics etc..
then a basic cheaper end of the price range model for less than £30 could be more than adequate..
Have a search for multi-meters at Halfords / Screwfix / Toolstation websites.. etc..
They all have some reasonable hobby / DIY meters..
(Before Maplin's went bump they also had a decent range of good value test meters).
But if you are looking to get into a bit more serious electrical work where reliability, accuracy and safety become higher priorities..
then you will need to be looking at spending a bit more..
As many of the cheaper meters are NOT reliable devices for verifying if AC mains voltages are present on a circuit.
So you probably need to search specialist sites for test meters such as isswww.co.uk, a previous forum sponsor..
https://isswww.co.uk or other similar types of suppliers..
What is it you are looking to do?
Guinness
