If flat is 0 degrees, 120 degrees should be 30 degrees past vertical, so for thorough cooking it needs to be tipped over a bit more. Else cooking times will be protracted.
Instructions often say "preheat the oven to" for example gas mark 5. I know someone who preheated just as it said put his pie in the oven and turned the oven off. "
