Colin Smith
- Oct 2, 2013
- 3
- 0
Hi All,
WC Cloakroom with extractor fan on lighting circuit.
The extractor fan has suddenly stopped working, I suspected it was the fan but found no power on the permanent live feed or the switched live when the light is on. The fan was wired from the cieling rose and I have power there no problem (the light works) and the other end of the cable going to the fan has power.
A continuity check between the ceiling rose and the fan shows an open circuit on all wires, (Earth, switched live, perm live and neutral) suggesting the whole cable has suddenly become severed! The cable run between the rose and fan is behind plaster board and in the ceiling void beneath a tiled floor upstairs, so I can't visualy inspect the cable.
What could be the cause of loss of continuity on all four wires in the cable? I don't have any shorts across the cable either, so no evidence of rodent nibbling and no other work has been done in the vacinity.
Any ideas?
Any ideas?
