psrkallez06
- Nov 11, 2015
- 11
- 0
I just noticed that i can't post pictures without 10 posts.. How can i post/show the images? Thanks!
Buy a power supply where you don't need to mess about with mains voltages, building your own safe power supply is not a cheap and simple job without any experience.Oh. what is a choke? Bit of a noob here haha. I just want to convert 230v AC to a lower and safer value to work with.
not going to get far with a choke... best buy something designed for the jobOh. what is a choke? Bit of a noob here haha. I just want to convert 230v AC to a lower and safer value to work with.
Thanks!
A bloody big bill for a funeral for someone by the sounds of things.You are going to kill yourself or someone!
What are you trying to achieve?
Hi, sorry to say this, but that is not how it works. You need to buy the correct transformer, you can't "just pinch one from something you found"Trying to build a a power supply that can supply around 20 amps @14 volt.
And i have everything except a transformer and i can't afford one atm. So I'm looking for one
I have said it before....only difference is that this time the WHOOOMPFHHHHHHH. May be a bit biggerConnect that to the mains and.....kerfurkingboom....and not in a good way
Just saying
That is neither a transformer, nor is it big. A big transformer that is safe for your use would be one of these; http://gizmodo.com/5983072/the-biggest-transformer-ever-made-metroplex-and-all-the-new-transformers-from-toy-fairThanks for all the answers! So i found this ballast in my basement for a 400W HPS growing light. I took it apart and found that it has a BIG transformer. At least i think it's a transformer haha, same as before. do you have any idea where AC in/out goes?
I would guess that AC in goes on the pins to left and AC out to the left. But it doesn't hurt to ask
Cheers!
