I have a circuit consisting of a single pahse 230v radial circuit serving 3x 2kw fan heaters. 2.5mm squared pvc single core cables instaled in pvc conduit and metal trunking clipped to the surface. A single phase consumer unit with 20A mcb protection. Other info provided is: measured earth fault loop impedance is 0.57 ohms and the measured prospective fault current is 0.4kA.
What other other info do i need to undertake cable calcs? am i right in thinking its just the 4 factors plus cable length? - ambient temp, grouping, insulation and type of protection?
How do i work out the expected voltage drops and the current at each load? - what is the formulae?
Andrew McEvoy
Andrew McEvoy
