Hello,
I'm just doing some research, but I need a plug socket put on a wall in my living room, thing is the nearest 'feed' for the spur that I can see is a nearby socket opposite out 2m away through a doorway. My living room has a concrete floor and I want to see if I can buy some flush floor conduit/trunking, but can't seem to find any. I was going to channel out the concrete and lay the conduit/trunking down so it is flush and I can lay the carpet down and you won't feel it when you walk over it, or can you think of a better way?
I will also be adding some coax and hdmi cables through this passage to the other wall too.
