Hi All,
I have several computers connected to a trailing socket which takes it's power from a standard wall socket. I need to move the supply of power from this existing wall socket to another wall socket. However I cannot remove power from the trailing socket as the computers need to stay powered up.
My plan is to create a "once only use" cable with 13A plug at both ends.
Plug one end into an unused wall socket and the other end into one of the trailing socket's sockets. Thus supplying the trailing socket from 2 wall supplies.
I'll then unplug the trailing socket from the 1st wall socket and connect it to the 2nd wall socket (being careful with the exposed "live" plug of course)
Finally I will remove the temporary "Dual plugged" cable from both the wall socket and the trailing socket and disassemble this cable so it can't be plugged in again by mistake.
I fully understand the dangers from the live plugs and also know that this is bad practice HOWEVER it is in a domestic situation and all caution will be be used when carrying out the transfer.- I cannot disconnect the computers.
Will this work? I see no reason why not but I'm not too proud to get a second opinion.
