Hi Guys , please bear with me if some of my terminology is incorrect
I'm fitting a power shower for a friend , the set up is
vented heating system with hot water cylinder in cupboard on landing
tank in loft on a platform , ( about waist height)
plan that is underway is -
fit a surrey flange ( :innocent ) to top of the cylinder , loop pipe work to the base of cylinder ( anti gravity loop) before going straight up to the pump , pump is situated on the loft floor below water tank .. all in 22mm
drill plastic loft tank , fit 22 tank coupling and take 22mm cold to pump, fit gate valves , then out to showers
am i correct in thinking that a POSITIVE HEAD pump is OK for the job in hand? , is the anti gravity loop OK to prevent air locks?
Friend wants pump in loft not in the airing cupboard
any advice welcome
I'm off to a find a surrey flange
Cheers
Ste
any advice welcome
Cheers
Ste
