- Dec 25, 2011
- 5,470
- 80
Hi, I have a 20A DP switch on a 2.5mm ring that feeds a single, unswitched socket under a worktop via a single 2.5mm cable. The DP switch has a built in neon. My question is this: For carrying out the ring final circuit tests at the CU how do I "allow" for the neon? Obviously I have to switch the DP switch on when dead testing to bring the single socket in circuit for testing but I don't want the resistance of the neon bridging line and neutral while I test.
We covered this at college as far as them saying ""Make sure there's no neons in circuit......" but that's as far as it went. Ideally I would remove the neon but it's pretty much integral to the DP switch. It looks like I could take the back off of the DP switch plate by 4 screws but I'm thinking lots of springs and bits to fall apart!
Am I missing something here, is there an easy way. Going to dig out my Scadden book on Inspection & Testing and have a read!
Thanks in advance.
Thanks in advance.
