No you did fineIts safe as long as you don't disconnect it from the bar and grab the end , not to be recommended Dan, so its part of the live circuit . Or say as flow and return , its the return. It is carrying the return current . The neutral is earthed by the supply company at the star point at source so that those currents are carried safely away but not using the earthing system of a building.Perhaps someone else can explain it more clearly , I'm starting to waffle.
deke
stick your tester between an open neutral and you will soon see why its treated as liveso....why do we treat neutral as dangerous as live?
thats still 404 lines more than my reply!Specs,s posts are much better coz they are in colour , I,m still in B&W 405 lines. He waffles on the same as myself but almost makes sense in colour !! ; \
Deke
Neutral will be at or around 0V unless there is a fault, in which case it may rise. If a circuit goes O/C, neutral will go to higher voltage. in a house, thats 230V. if its 3 phase, depending on loading, it could get to 400Vthe point im getting at is that,we treat neutral as tho its at 230v(i do anyway)yet in a CU its not insulated.if a few circuits are using power then 230v is going to be returning via neutral right?so is the neutral bar not then live? ?:|
Your just a tight wad and don't want to pay the full colour licence to Admin!!!!Specs,s posts are much better coz they are in colour , I,m still in B&W 405 lines. He waffles on the same as myself but almost makes sense in colour !! ; \
Deke
Maybe meet half way and give an extra colour for same price? like black, blue and white?!Your just a tight wad and don't want to pay the full colour licence to Admin!!!!stick in the mud b&W licence's:_| X(
well i have now paid for a COLOUR license from admin cost me an arm, and a leg, and my nose though :^O :_| :_|Your just a tight wad and don't want to pay the full colour licence to Admin!!!!stick in the mud b&W licence's:_| X(
Better than getting knocked about until your black and blueI still get mixed up withbrown and red
The thing you have to remember Dan is..the point im getting at is that,we treat neutral as tho its at 230v(i do anyway)yet in a CU its not insulated.if a few circuits are using power then 230v is going to be returning via neutral right?so is the neutral bar not then live? ?:|
you never get a good BROWN on pc's!!! X( :_|I still get mixed up withbrown and red
Try it this way Dan, the Potential Difference between live (brown) and earth is 240volts . The PD between live and neutral is 240 volts. The PD between neutral and earth is 0 volts (zero) Notice in a metal dist board that the earth bar is bolted to the case but the neutral bar is insulated from the case but still open to the touch.the point im getting at is that,we treat neutral as tho its at 230v(i do anyway)yet in a CU its not insulated.if a few circuits are using power then 230v is going to be returning via neutral right?so is the neutral bar not then live? ?:|
