I’m rewiring my garage (not physically connected to my house - SWA supply cable running under the drive way) in preparation for it to be converted to a room. Fed from a garage CU with 40A 30mA RCD circuit 1 is a 6A radial circuit for 3 x outside lanterns, 6 x LED spot lights and a suspended LED panel. Circuit 2 is a 32A ring main with 5 x double sockets. I’ve run all of the cables and continuity tested them without the supply cables connected to the consumer unit, they all test okay so no issues. The room hasn’t been boarded out so I just wanted to connect the outside lights temporarily. As soon as I connected them and turned on the MCB the RCD tripped, I immediately thought that there could be. Fault in a lamp so disconnected them one by on, each time I disconnected a lamp I tested and the RCD tripped. No lamps are connected and it’s fine, 240V through the switch common to L1. I tested for continuity again, this time in the consumer unit and to my surprise found the Neutral and Earth at 0.3ohms. I disconnected the supply cables from the house consumer unit and tested the outside light cable from the consumer unit to the switch and this was fine. I tested the supply cable from the house again and saw the same 0.3ohms from neutral to earth - I assumed a cable fault on the cable under the drive way but could see how it could have happened. I went into the house and tested across the neutral and earth terminal bar and saw the same 0.3ohms, the power in my house seems fine, all of the lights and sockets work and I don’t have MCB or RCD tripping issues. I disconnected the live, neutral and earth cable supplying the garage from the house consumer unit and tested again, expecting to see the fault on the cable with the same neutral earth continuity but the cable was fine. I tested again in the house consumer unit on the terminal bars and saw that the neutral and earth still had continuity.
I’m completely puzzled, before I started this there was a very simple arrangement with the outside lights and an LED strip light fed from a 6A breaker and a single double socket fed from a 16A breaker, I’ve never known the RCD to trip. Has anyone seen this before, I’m sure it’s not normal to have this Neitral Earth continuity. Sorry for the war and peace, just looking for comments before I start disconnecting circuits one at a time in the house consumer unit to find the circuit that has the IR fault. Thanks
