Sarahabarth
- Joined
- Apr 28, 2018
- Messages
- 11
- Reaction score
- 0
Hi,
the neutral wire on my immersion heater has melted about 5 times in the last year. I've had the thermostat changed twice but the same thing keeps happening.
the thermostat has a reset and is set to 60 degrees. The boost (thankfully) has been okay as I use it very rarely.
everytime I tell my electrician about the problem he spends about 5 mins rewiring then says it should be fine and that there's not much else we can do but keep an eye on it. He said last time he had used heat resistant wire and extra thick - I think 2.5mm? I'm not technical so I'm not sure.
Anyway the problem still hasn't gone away and I'm sick of just ringing the electrician every other month so come and sort and the problem doesn't seem to be getting fixed.
If anyone has any advice of what the problem could be and how it could be rectified that would be much appreciated!
