Willengland
Hi everyone,
Am hoping someone can help.
I have a new Solax X1 PV 3kwh system. I believe its the Boost model. Although am not 100% sure on that one. As cant seem to see it on any of the paperwork or inverter, which I can understand isn't probably very helpful. I got the system through a grant scheme due to my disability.
But my issue is with the CT clamp and the data its showing. The installer didn't fit the CT clamp, however the kit did come with one and he left it behind. He said I didnt need it fitting due to not having batteries. However I wanted it fitted so as I could see all the correct data through the app ie how much pv producing and how much importing and exporting from the grid and my usage.
The clamp had now been fitted, I believe from what I've read in all the manuals and online that its fitted to the correct wire and with the arrow in the correct direction. Its clamped to the live wire that comes directly from the main house smart meter to the consumer unit, with the arrow on the CT clamp pointing towards the meter and away from the CU. Ive also tried relocating the clamp to the positive wire Before the meter with the same results. However the data its showing in the app seems to be completely wrong. It seems to be showing my actual Usage under the Feed in section and then adding it to the PV production and showing both together under the Load/Generator section.
Also the graphs seem to be completely wrong and dont make any sense.
Has anyone got any ideas on what's going wrong? Any help really would be greatly appreciated.
Many thanks
Many thanks
